Community Member
Is SNMP RO and telnet good enough for IPM?
Dear friends,
I have only SNMP RO access to the router and telnet access as well from Ciscoworks LMS.
But i dont have SNMP RW access.
Is it possible that i configure ip sla monitor manually on the routers / switches and just use IPM to poll these routers and collect the SLA statistics?
Thanks a lot
Gautam
1 REPLY
Re: Is SNMP RO and telnet good enough for IPM?
IPM requires read-write access.  However, you could try configuring the collectors on the devices manually, then import those collectors into IPM using the "ipm importcollector" cli command.  I haven't tested doing this without having SNMP RW configured, but it should work.  IPM will just not be able to fully manage the collectors, but it should be able to poll them.
161
