Community Member
Is there a way to determine the OID's for specific show commands ? I'm LOST
PEE_VOICE_2#sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x19E12 782 0x467EE400 0/0/0:15.4 0/2:4 224 g729r8 105/95
0x19E1E 787 0x467EE400 0/0/0:15.5 0/2:5 210 g711alaw 105/95
0x19E21 1C3A 0x46950E8C 0/0/1:15.31 0/2:2 *3139966251 g711alaw 200/103
0x19E26 78A 0x467EE400 0/0/0:15.8 0/6:3 210 g729r8 105/95
0x19E28 78B 0x467EE400 0/0/0:15.6 0/2:6 210 g729r8 105/95
0x19E36 78F 0x467EE400 0/0/0:15.1 0/2:3 210 g711alaw 105/95
0x19E38 790 0x467EE400 0/0/0:15.7 0/6:2 226 g729r8 105/95
0x19E3B 1C66 0x46950E8C 0/0/1:15.30 0/6:4 *3139966251 g711alaw 200/103
0x19E3E 792 0x467EE400 0/0/0:15.9 0/6:5 224 g729r8 105/95
0x19E40 793 0x467EE400 0/0/0:15.10 0/6:6 211 g711alaw 105/95
0x19E42 794 0x467EE400 0/0/0:15.11 0/11:1 226 g711alaw 105/95
0x19E45 1C78 0x46950E8C 0/0/1:15.29 0/2:1 *3139966251 None 200/103
12 active calls found
I want to monitor the total active calls found property !
Is there a toll/command to determine an OID for a specific show output ?
Re: Is there a way to determine the OID's for specific show comm
This might help:
---A-----
To get just the count of VoIP active calls the simplest way is to count
the number of entries that you get in the object cvVoIPCallActiveTable.
Sometimes this may not be accurate so it is good to verify that for each
entry in cvVoIPCallActiveTable, there is an entry in callActiveTable. If
not, drop those ones from the count.
To further refine this to distinguish between calls that are in
connecting, connected or active state you can use the
callActiveCallState in callActiveTable.
The oid used above are as follows :
CISCO-VOICE-DIAL-CONTROL-MIB: "cvVoIPCallActiveTable"
"1.3.6.1.4.1.9.9.63.1.3.2"
DIAL-CONTROL-MIB: "callActiveTable"
"1.3.6.1.2.1.10.21.1.3.1"
DIAL-CONTROL-MIB: "callActiveCallState"
"1.3.6.1.2.1.10.21.1.3.1.1.9"
Also for Historical data, the following looks promising :
CISCO-VOICE-DIAL-CONTROL-MIB: "cvCallHistoryTable"
"1.3.6.1.4.1.9.9.63.1.4.1"
-----B------
To get something similar to the information of the command "sh call
voice active brief" you could do something like what I have below: (have
provided the MIB info next to it, for easier understanding)
H323 leg
pid: pid:200
callActivePeerId.291909790.1 = INTEGER: 200
Answer
callActiveCallOrigin.291909790.1 = INTEGER: answer(2)
205
callActivePeerAddress.291909790.1 = STRING: 205
active
callActiveCallState.291909790.1 = INTEGER: active(4)
tx:/ tx:85515/13681843
callActiveTransmitPackets.291909790.1 = Gauge32: 85692
callActiveTransmitBytes.291909790.1 = Gauge32: 13710323
rx:/ rx:85441/13670560
callActiveReceivePackets.291909790.1 = Gauge32: 85621
callActiveReceiveBytes.291909790.1 = Gauge32: 13699680
For the Telephony leg
pid:1
callActivePeerId.291909815.1 = INTEGER: 1
Originate
callActiveCallOrigin.291909815.1 = INTEGER: originate(1)
93928027
callActivePeerAddress.291909815.1 = STRING: 93928027
active
callActiveCallState.291909815.1 = INTEGER: active(4)
tx:/ tx:85442/13670720
callActiveTransmitPackets.291909815.1 = Gauge32: 85619
callActiveTransmitBytes.291909815.1 = Gauge32: 13699360
rx:/ rx:85515/13681843
callActiveReceivePackets.291909815.1 = Gauge32: 85695
callActiveReceiveBytes.291909815.1 = Gauge32: 13710963
Community Member
I tried those OID's before but without any result ( do I need to do it on device or interface or ? )
113
