Community Member
[ ISC - 5.0.1 ] Problems with desciptions in VPLS Services
I have faced an issue regards with Interface Vlan description for a VPLS Service.
ISC has put UNI description in Interface Vlan description for each link of the SR, so, at the end of deployment, Interface Vlan had UNI description of the last link created in the service and all of the other links goes to failed state in Audit ( Audit Failed: description not found).
Do someone has any idea how to fix this problem?
1 REPLY
Silver
Re: [ ISC - 5.0.1 ] Problems with desciptions in VPLS Services
Check the bug: CSCsb45192: VPLS audit msg display vlan descp instead interface descp
http://www.cisco.com/en/US/docs/net_mgmt/ip_solution_center/5.0/metro_ethernet/user/guide/mg_audit.html
115
