ISDN Logging
my god ISDN bill is going up . is thr any tool to log/monitor call of ISDN on cisco 2851 router ? , i check router with all isdn related command nothing get. please suggest any 3rd party tool to access ISDN logging
Re: ISDN Logging
You better can make use of simple syslog to find out when the isdn is getting connected and disconnected.
Also you can have the idle timeout timers reduced to minimum value so that they can disconnect once they stay idle for the defined period of time.
If you are running any routing protocol then better to have demand based (snap shot routing) updates to the peer router.
regds
Re: ISDN Logging
nice. but seperam i wanna monitor calls logging for billing deatils
125
