Webcast-Catalyst9k
ISDN total current channels in use
Does anybody knows an OID to get (just in one snmpget) the total amount
of channels currently in use by an ISDN interface?
I've found the "isdnBearerOperStatus" entry which works fine, but since
it is a per channel entry, it should be performed on every channel of
an ISDN interface and then processed by a script to get the all
channels usage number..
Thnx in advanced!
1 REPLY
Re: ISDN total current channels in use
How about this object:
CISCO-POP-MGMT-MIB -- cpmISDNCfgBChannelsInUse
"The number of configured ISDN B-Channels that are
currently occupied by both Digital and Analog calls"
115
