Issue:Creating Ip Sla operation using snmp
Who can explain why I can't set createAndGo or createAndWait in rttMonCtrlAdminStatus?
Maybe it is a security problem?
1 ACCEPTED SOLUTION
Re: Issue:Creating Ip Sla operation using snmp
You must set all of these in the same packet. Trying to set them in individual requests will fail.
Please provide exactly what you are trying to do including all objects you are setting and their values as well as the device and IOS version you are using. What error are you receiving?
Device info:
Cisco IOS Software, C2600 Software (C2600-ENTBASEK9-M), Version 12.4(13), RELEAS
I am trying to set following objects:
rttMonCtrlAdminStatus. -Integer 4 or 5 rttMonCtrlAdminRttType. -Integer 9
rttMonEchoAdminProtocol. -Integer 27
rttMonEchoAdminTargetAddress. -OctetString "05 00 00 02"
rttMonEchoAdminTargetPort. -Integer 8000
rttMonEchoAdminInterval. -Integer 20
rttMonEchoAdminNumPackets. -Integer 100
rttMonScheduleAdminRttStartTime. -TimeTicks 1
I am reciving such SNMP error Ber Api overflow.
Note:Using CLI to configure jitter operation work fine.
Please help me!
Do this all in one request, and it will work for you:
The objects must be specified in that order.
Unfortunately, I am reciving same error when try to
set rttMonCtrlAdminRttType. -Integer 9
If i understand rttMonCtrlAdminStatus(createAndGo or createAndWait) is used to create a new instance of a conceptual row and make it available for use.
Thanks a lot it work.
Can you provide me the info, which describe this approach?
if I understand all configuration IP SLA operation must be send in the same packet for all device?
I don't have anything other than what I just told you regarding information on this. Yes, setting all objects in the same request is the way to do it.
290
