Webcast-Catalyst9k
issue is with SNMP V3
Hi ,
I have configured below SNMP v3 commands in cisco Router 7206VXR (NPE-G1) . I have tested with all option but it is not working . SNMP server is a SNMPc tool and I have configured user name and piv and auth credential correctly in both side . Same configurations is working for all cisco switeches but not working for Cisco Router.
Can any one please help me on this .
SNMP V3 configurations:
access-list 20 permit 43.194.10.0 0.0.0.255
snmp-server view readview iso included
snmp-server group readonly-group v3 priv read readview access 20
snmp-server user isenetworkteam readonly-group v3 auth sha Allviewtov3devices priv des56 Sony3make0believe access 20
snmp-server host 43.194.10.100 version 3 priv isenetworkteam
snmp-server enable traps
Router :
Host Name# sh version
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 12.2(33)SRD7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 20-Sep-11 12:52 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)B, RELEASE SOFTWARE (fc1)
GB-BAS-DC-IR1 uptime is 22 weeks, 5 days, 13 hours, 23 minutes
System restarted at 20:43:30 UTC Sat Feb 11 2012
System image file is "disk2:c7200-advipservicesk9-mz.122-33.SRD7.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G1) processor (revision A) with 983040K/65536K bytes of memory.
Processor board ID 30829375
SB-1 CPU at 700Mhz, Implementation 0x401, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.7
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 200 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62976K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Thanks a lot in advanace for support
Reagards,
Ram Kumar
Everyone's tags (2)
The configuration looks good.
Just check if the snmp v2c works fine on your device to NMS. it will be good to check if the snmp is responding on device and no ACL issues.
Eg:
snmp-server community xxxxxx RO 20
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thanks for your reply.
I have checked with access list 20 and SNMPv2c is working .
Ram
I copied your config to my device and it is working perfectly fine.
But, unfortunately my device does not support priv mode of DES56. I would request you to try another priv mode as well like DES.
Please check when you try to do snmpwalk on you device using NMS does the input packet increase? You can check that on show snmp.
Try to do a snmpwalk from any other NMS if possible,as it is mostly not on the config side.
-Thanks
Vinod
1016
