08-25-2013 11:42 PM
hi every body ,
first problem :
I integrated CPI with ACS and i add super admin specially to authenticate against ACS , although the authentication working fine through the ACS but some of features are disappear . However when i login locally by same user role the features are appear .
second problem:
Some of switches like 3750,3550 ,are shown unknown in temperature field in detail dashboard , while the other types like 6500 are shown the actual temperature .
08-26-2013 05:31 AM
- Which features appear and or disappear ?
M.
08-26-2013 09:25 PM
these features :
Custom SNMP Template
Moinitoring Configuration
Associate End points to the Site
08-26-2013 10:46 PM
Send me your SNMP configuration
and monitoring configuration
and through which level of user you are monitoring
Rate it
08-26-2013 11:15 PM
aman
when i try to login with Tacacs (ACS) the custome snmp feature disappear and that user is configured as Admin role but through ACS not locally .
However when i login with local admin role i can see this feature.
09-02-2013 04:34 AM
I solved the first problem by readding the tasks in ACS.
For the tempature i try adding internet ,system ,interfaces ,cisco ,chassis in SNMP view but still the
temperature value Unknown for 3750 switches
