java.lang.NullPointerException in CiscoView
Hi all,
using CiscoView with a 2950 trying to configure a port results in a java.lang.NullPointerException. Doing the same on a 2960 works fine.
I already deleted and reinstalled Version 6 of Cat2950 package but it didn't solve the issue.
What can I do?
1 ACCEPTED SOLUTION
Re: java.lang.NullPointerException in CiscoView
From what I can see the CiscoView package supports the 2950 if it runs 12.1(19)EA1 or later.
What version of code are you running on the 2950? What version of CiscoView?
acutally the versions are the following:
LMS 2.5
CiscoView 6.1.4
CV Package cat2950 v6.0
Device cat295048g (C2950-I6Q4L2-M)
IOS 12.1(6)EA2a
Chasis -> Configure works fine.
Port -> Configure gets Failed to create dialog due to java.lang.NullPointerException
Port -> Monitro works fine
Ruedi
136
