Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Job to reload switches
What is the best/only way to create a job to reload several switches at once?
I was thinking to go to RME,config mgmt, netconfig jobs, and create and adhoc job that says reload. Is there a better option?
1 ACCEPTED SOLUTION
Re: Job to reload switches
Yes and no. Go to Netconfig, and create an ad hoc job to deploy a "reload at" command. Assuming all of the switches have NTP, they will all reload at the exact same time. If you scheduled a Netconfig job to actually perform the reload operation, not all the switches would reload at exactly the same time.
Sounds good. I don't really need them to reboot at the exact same time, but close, just wanted to confirm that this was the best way to accomplish this. Thanks.
124
