07-21-2006 05:09 AM
Anyone knows if LMS 2.5.1 support JRE 1.5?
07-21-2006 08:38 AM
It does not support JRE 1.5. The latest support looks to be JRE 1.4.2_10 with a patch loaded from this link:
07-22-2006 01:09 PM
Good thing is that LMS doesn't waste time on checking you java until it realy needs it.
Right now only certain Campus pages require the "supported" java version. The rest of LMS works with most java's.
Cheers,
Michel
07-22-2006 02:14 PM
The IPM 2.6 web client also requires the Java Plug-in.
