JRM is down
vaibhav-g
Hi eam
JRM service is not coming up..plse find the atached error message.
regrds
Vaibhav
Check to make sure 172.28.100.10 is still the correct IP address for this server. If not, update the entries in gatekeeper.cfg, then restart Daemon Manager.
29 Replies 29
vaibhav-g
plse find the attached error logs
Vaibhav
Post the jrm.log and CTMJrmServer.log.
Hi Clark
sorry for the delayed response, plse find the required logs
Vaibhav
You did not post the jrm.log. I'm also not sure why you're trying to reinitialize the cmf database. At this point, that seems to be overkill, and may not fix the underlying problem.
Hi Clark
we will soon provide you the JRM.logs
Vaibhav
Hi Clark
Vaibhav
Hi Clark
I have alredy attached the JRM.log file
plse help me..
Vaibhav
Jrm appears to be working just fine. Was the hostname on this server changed? Post the output of the command:
pdreg -l CTMJrmServer
And the NMSROOT\lib\classpath\md.properties file. Additionally, it appears Daemon Manager has been up since 8/6. Simply restarting may get things back in sync.
Hi Clark
Vaibhav
This looks good assuming the hostname of the server is ciscolms. Is this problem still occurring? Have you tried restarting Daemon Manager? It could simply be a timing issue.
Hi Clark
we have tried to restart the daemon manger service but still we are facing same issue.Plse find the attached file for hostname.
Vaibhav
Post the output of the DOS SET command, and the NMSROOT/MDC/tomcat/logs/stdout.log.
Hi Clark
plse find the required logs.
Regrds
Vaibhav
Post screenshots of the Services control panel showing all of the CiscoWorks services. Additionally, the pdshow appears truncated. Run:
pdshow > pdshow.txt
Then post the pdshow.txt.
