JRM is down
vaibhav-g
Hi eam
JRM service is not coming up..plse find the atached error message.
regrds
Vaibhav
29 Replies 29
Hi Clark
plse find the required logs
Vaibhav
The services look okay, but the pdshow is still truncated. Did you run:
pdshow > pdshow.txt
That will capture the entire output.
Hi Clark
plse find the required logs.
Vaibhav
The RmeGatekeeper is down. Post the output of netstat -a -n -o -b from the server as well as the RmeGatekeeper.log.
Hi Clark
Vaibhav
Your netstat output is truncated. Run this command:
netstat -a -n -o -b > netstat.txt
Then post the netstat.txt. One of the ports required by RmeGatekeeper is in use by another process.
Hi Clark
Vaibhav
There was something bound to one of the RmeGatekeeper ports, but all the ports appear to be free now. You should be able to restart the RmeGatekeeper, and have it stay up. Try running:
pdexec RmeGatekeeper
Then verify it stays in a running state. If so, restart Daemon Manager, and that should allow all of the daemons to resync.
Hi Clark
Tried to start the RmeGatekeeper but it does not stay up and get down in few minutes.
Vaibhav
Post the NMSROOT/lib/vbroker/gatekeeper.cfg file.
Hi Clark
Vaibhav
Check to make sure 172.28.100.10 is still the correct IP address for this server. If not, update the entries in gatekeeper.cfg, then restart Daemon Manager.
Hi Clark
thanks for your response, i will check the same and upadte you,
If i found different Ip than i need to replace that IP address in Gatekeeper.cfg file, Plse confirm
Vaibhav
Yes.
Hi Clark
Thanks a ton..yes their was a IP conflict issue.Now issue was resolved by replacing the same..
Thanks again
Vaibhav
