Community Member
JRM is down
Hi eam
JRM service is not coming up..plse find the atached error message.
regrds
Vaibhav
1 ACCEPTED SOLUTION
Re: JRM is down
Check to make sure 172.28.100.10 is still the correct IP address for this server. If not, update the entries in gatekeeper.cfg, then restart Daemon Manager.
Community Member
Re: JRM is down
plse find the attached error logs
Vaibhav
Re: JRM is down
Post the jrm.log and CTMJrmServer.log.
Community Member
Re: JRM is down
Hi Clark
sorry for the delayed response, plse find the required logs
Vaibhav
Re: JRM is down
You did not post the jrm.log. I'm also not sure why you're trying to reinitialize the cmf database. At this point, that seems to be overkill, and may not fix the underlying problem.
Community Member
Re: JRM is down
Hi Clark
we will soon provide you the JRM.logs
Vaibhav
Community Member
Re: JRM is down
Hi Clark
Vaibhav
Community Member
Re: JRM is down
Hi Clark
I have alredy attached the JRM.log file
plse help me..
Vaibhav
Re: JRM is down
Jrm appears to be working just fine. Was the hostname on this server changed? Post the output of the command:
pdreg -l CTMJrmServer
And the NMSROOT\lib\classpath\md.properties file. Additionally, it appears Daemon Manager has been up since 8/6. Simply restarting may get things back in sync.
Community Member
Re: JRM is down
Hi Clark
Vaibhav
Re: JRM is down
This looks good assuming the hostname of the server is ciscolms. Is this problem still occurring? Have you tried restarting Daemon Manager? It could simply be a timing issue.
Community Member
Re: JRM is down
Hi Clark
we have tried to restart the daemon manger service but still we are facing same issue.Plse find the attached file for hostname.
Vaibhav
Re: JRM is down
Post the output of the DOS SET command, and the NMSROOT/MDC/tomcat/logs/stdout.log.
Community Member
Re: JRM is down
Hi Clark
plse find the required logs.
Regrds
Vaibhav
Re: JRM is down
Post screenshots of the Services control panel showing all of the CiscoWorks services. Additionally, the pdshow appears truncated. Run:
pdshow > pdshow.txt
Then post the pdshow.txt.
Community Member
Re: JRM is down
Hi Clark
Vaibhav
Re: JRM is down
The services look okay, but the pdshow is still truncated. Did you run:
pdshow > pdshow.txt
That will capture the entire output.
Community Member
Re: JRM is down
Hi Clark
Vaibhav
Re: JRM is down
The RmeGatekeeper is down. Post the output of netstat -a -n -o -b from the server as well as the RmeGatekeeper.log.
Community Member
Re: JRM is down
Hi Clark
Vaibhav
Re: JRM is down
Your netstat output is truncated. Run this command:
netstat -a -n -o -b > netstat.txt
Then post the netstat.txt. One of the ports required by RmeGatekeeper is in use by another process.
Community Member
Re: JRM is down
Hi Clark
Vaibhav
Re: JRM is down
There was something bound to one of the RmeGatekeeper ports, but all the ports appear to be free now. You should be able to restart the RmeGatekeeper, and have it stay up. Try running:
pdexec RmeGatekeeper
Then verify it stays in a running state. If so, restart Daemon Manager, and that should allow all of the daemons to resync.
Community Member
Re: JRM is down
Hi Clark
Tried to start the RmeGatekeeper but it does not stay up and get down in few minutes.
Vaibhav
Re: JRM is down
Post the NMSROOT/lib/vbroker/gatekeeper.cfg file.
Community Member
Re: JRM is down
Hi Clark
Vaibhav
Re: JRM is down
Community Member
Re: JRM is down
Hi Clark
thanks for your response, i will check the same and upadte you,
If i found different Ip than i need to replace that IP address in Gatekeeper.cfg file, Plse confirm
Vaibhav
Re: JRM is down
Yes.
Community Member
Re: JRM is down
Hi Clark
Thanks a ton..yes their was a IP conflict issue.Now issue was resolved by replacing the same..
Thanks again
Vaibhav
418
