Juniper SXR 240 add to cisco prime
midhun_km
Hi All, Good Morning,
Can we add Juniper SXR 240 Switches Cisco Prime Infrastructure...?
Urgent Help needed , waiting for replys....
Midhun Madhu
Wilson Sy
Hello Midhun,
Juniper is not supported by Prime Infrastructure,  the only 3rd party device that is currently supported is Aruba wireless controllers and access points. You can refer to the supported devices list from the link below:
Compatibility Information
http://www.cisco.com/en/US/products/ps12239/products_device_support_tables_list.html
Release Notes for Cisco Prime Infrastructure, Release 2.0
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/2.0/release/notes/cpi_rn.html#wp43885
BR,
Wilson
