Licence or PAK ID for Reinstall 2.6 ?
On Windows 2003 server it is installed a CW LMS 2.6 (after upgrade 2.2 to 2.6) and now I want to re-install the same LMS apllication on an other plateform:I is it necessary to have a licence and/or a PAK ID? What is the procedure to have the Licence and/or the PAK ID?
Thanks for your helps.
Omar ATTOUMANI
1 REPLY
Re: Licence or PAK ID for Reinstall 2.6 ?
oh, the procedure to get a license and let run the same LMS application on another server at the same time as the first one is running, is very simple:
just buy another license ! ;-)
the license doesn't care about the platform but about the number of installations
When you 've got one license for LMS 2.6, it can be used for 1 instance of each application in LMS 2.6 - except of Common Services (former CDone)-which does not need to be licensed.
So every additional installation of the same application needs a new license .. (2 RME installations = 2 LMS licenses)
185
