License ambiguity after upgrade from LMS 4.0.1 to Prime 2.1
Heiko Kelling
I've made at a customer the update from lms 4.0.1 to prime 2.1.
Because of the long and difficult upgrade path I have decided to make a new installation of Cisco Prime and import the devices manually and with auto discovery.
That has it all works very well.
For the upgrade I had 2 licenses:
+ R-L-PI2X-U-K9 (LMS to Cisco Prime Infrastructure 2.x Upgrade) with L-L-PI2X-100-U (LMS to Prime Infrastructure 2.x Upgrade 100 Device)
+ L-PILMS42-KIT (Prime Infrastructure - LMS License Kit)
The first license works well in Prime, but second license not. It´s a LMS license and I don´t know how to install it.
If I log in the prime I get the error message: "Warning: Base license is missing. Please install a base license"
Has it to do with that I have not followed the upgrade path and how can I fix the problem?
Thanks in advance
AFROJ AHMAD
Hi ,
The steps you have followed are fine so PI is a fresh install , I would say.
as you are getting the error for base license , you need to reach out to license team , they will issue the Base License for prime Infrastructure and then you can apply the Lifecycle License.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
I have opened a license case but the TAC can give me only a temporary license because of the service level. He said I need a SASU / SAU contract.
How about installing this license R-L-PI2X-U-K9 after installing this temp license.
Thanks-
I will forward it to our customer. They can test it. But I think that will not work, because the license R-L-PI2X-U-K9 seems to be a sheer lms license. The name of the issued license is LMS20140618xxxxxxxxxx.lic
