Community Member
Licensing for Cisco Prime 2.x
Checking the user guide
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-729223.html#wp9000420
is not clear for me what I have to order.Having 2 WLC and 25 licences on each. I need to minitor the AP only and use Cisco Prime for future deployment. I understand I have to order as a basic:
Part Number
Description
R-PI2X-K9
Cisco Prime Infrastructure 2.x
Software and Base License Options
R-PI20-SW-K9
Cisco Prime Infrastructure 2.0 Software
L-PI2X-BASE
Cisco Prime Infrastructure 2.x Base License
L-PI2X-LF-50
Cisco Prime Infrastructure 2.x - Lifecycle - 50 Device License
What is the benefit of having :
L-PI2X-AS-50
Cisco Prime Infrastructure 2.x - Assurance - 50 Device License
or
L-PI2X-GW
Cisco Prime Infrastructure 2.x Plug-and-Play Gateway RTU
It there enything else?
I need to be sure that we weill be quoted for what we need. First time installation
Thank you
1 REPLY
Community Member
Hi Jakub!
L-PI2X-AS-50 is an "Assurance License", it is how many Netflow capable devices you want to connect.
The feature enables you to see which protocol mix there are in your network, e-2-e performance,
application troubleshhoting and metrics collection etc. Handy if you have mission critical applications
and the budget for it. Smallest license is 25 devices (ex a router or WLC)
L-PI2X-GW is a new feature for automatic deployment/configuration of wired devices only.
A new Cisco device will prompt the network for a PnP Gateway, and if present, th Gw
will supply a predefined template. Have not had time to play with this one myself yet...
1687
