Community Member
Link Analyzer for a large LAN
Looking for protocol analyzer idea/suggestion for a large LAN network.
We currently have Fluke along with PE.
Most of their Link Analyzers will be end of life, end of support soon.
1 REPLY
Hall of Fame Super Silver
Re: Link Analyzer for a large LAN
SPAN (or RSPAN) you port of interest to one with a host running Wireshark (www.wireshark.org). Capture the traffic there and analyze it using that product. If you have an *nix host, grab the traffic using tcpdump and look at it raw or ftp the file to a host with wireshark - it can open tcpdump files.(Wireshark runs on *nix also.)
If you don't want to SPAN, you can use a splitter like a Gigamon to pull off optical traffic out of band.
Other options in include Sniffer / Remote Sniffer or Network Instruments' Observer.
177
