Listing newly discovered devices in Campus Manager
LMS 2.5.1
Windows 2000
Is it possible to produce a report from Campus that lists newly discovered devices? Let's say I have 5000 devices discovered so far. A new discovery is done and Campus finds 50 more devices. I would like to have a report of what those 50 new devices are. I would like to be able to produce this report at the whim of my management. They are interested in keeping a running total of device that are discovered.
1 ACCEPTED SOLUTION
Re: Listing newly discovered devices in Campus Manager
If you go to Campus Manager -- Admin -- Reports you can select the report Data Collection Metrics and generate it
Once you do it, it will show the collections, and a column showing newly discovered devices
Silver
I get a report like that from the DCR.
I scheduled an export of the devices to a .CSV file. Next I grep all lines that cary:
,myROcommstring,,,,,,,,,,,
as the newly discovered devices only have a RO community string set I can easily seperate them from the older ones that have the RW community and the login credetials set as well.
Michel
90
