Community Member
LMS 2.2 64 bit?
Does CiscoWorks LMS 2.2 support 64 bits applications?
LMS 2.5 support 64 bits applications?
DL
Red
Re: LMS 2.2 64 bit?
Both are 32 bit application
Community Member
Re: LMS 2.2 64 bit?
Context:
DFM 1.2 "false" threshold exceed.
Is it possible that if we have
a interface with a very high traffic
(counter over than 32 bits) DFM repport
a false threshold exceed?
DL
Community Member
Re: LMS 2.2 64 bit?
This message you are receiving from DFM is in the context of a counter on a network element, not the server hosting the CW DFM application. Generally speaking, there are two different sized counters, 32bit, and 64bit or High Capacity (HC) counters. These counters are used to store information about a particular network interface or event, such as how many packets have gone through an interface, or how many bytes.
A 32-bit signed integer counter, like the ifInOctets/ifOutOctets, will overflow or wrap at 2^31-1. Most modern NMS applications, and maybe even DFM, should have logic to figure out when a counter has overflowed or wrapped, but I think it is also dependent on DFM's polling interval (And if DFM solely relies on solicited SNMP traps, you can ignore most of what I'm about to say). If an interface is pushing an extremely large volume of bits through it, and it wraps N+1 times in a polling cycle, I don't know how you'd be able to detect that.
I personally do not have much experience with DFM, so I'm not sure exactly what you should do to resolve your issue, but hopefully this will help you understand the 32bit/64bit stuff.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800b69ac.shtml
Community Member
Re: LMS 2.2 64 bit?
How DFM 1.2 or 2.0 (polling and threshold)figure out when a counter has overflowed or wrapped ?
118
