LMS 2.2 Campus manager 3.3 IDU 7 & RME 3.5 IDU 7
Hi All,
I have LMS 2.2. It is working fine with campus manager 3.3 & RME 3.5 & with IDU 5. Now we have added some 3560-24PS-S
switches which is only supported only if I have IDU 7 for both CM & RME. But the problem is it is not available with cisco. The earlier IDUs & the later IDUs are available but particular IDU 7 is not available.
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-campus
Can anybody tell any other source to get it. So that almost all my problem with LMS 2.2 will be solved.
Thanks in advance
Sachi
David Stanford
I would go ahead and install IDU 8.0 as it only requires IDU 5.0 and both are available on this link:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme
Also, it might be worth upgrading to a newer version of LMS as 2.2 is End of Support.
Thanks a lot for quick response. In IDU 8 supported devices are 3560G & in IDU 7 it is 3560-PS so I was thinking if I directly going for 8 still I will not be able to get the 3560-PS. But I installed 8 & its working fine I discovered even 3560-PS even its not in IDU 8 supported device list.
I think the same thing will work for RME also.
Thanks again
Sachi
IDU 8 will have support for the devices in the previous IDU's, so it does support the 3560-PS.
