01-05-2006 01:49 AM
We have installed LMS 2.2 module.Can anyone tell me where do we need to put our networks PIX firewall's entry so that we can view the devices which are on the other side of the firewall.
01-05-2006 02:47 AM
I didn't get u..Have u already entered those devices in LMS ?
U can add PIX from RME-administration-inventory-add devices
And u need to open snmp ports 161 & 162 and icmp on firewall so that those devices will be reached/managed by LMS
Suhas.
01-05-2006 04:58 AM
If you are trying to add the PIX into Campus Manager, that won't work since the PIX doesn't support CDP.
If you want to manage the devices downstream from the PIX, then you may add one of those devices in your seed device list and run a discovery.
