Webcast-Catalyst9k
LMS 2.2 ID usage -
Is it possible to tell the last time an ID was used?
1 ACCEPTED SOLUTION
Red
Re: LMS 2.2 ID usage -
If you mean was the last time someone logged into
LMS 2.2, unfortunately not.
If you have it integrated with ACS, then the ACS logs will contain the info.
1 REPLY
Red
105
