LMS 2.2
Dear All,
Due to some reason I have to install & configure LMS 2.2 this time where everybody going for 3.1.
I have never experience with 2.2. The interface is totaly different .The sub-menus are different.
I need small help at this stage that when I am configuring the snmp credentils in SERVER CONFIGURATION>ANI SERVER>SNMP SETTINGS it is taking. After typing all the strings & other parameters when I am saving the same its not saving. Because of that I am not able to discover the devices.
Can anybody pls help me in this regard?
Thanks in advance
Sachi
Joe Clarke
You should know that as of July 1, LMS 2.2 will no longer be supported.
For this problem, you should check NMSROOT/campus/etc/cwsi/anisnmp.conf and make sure it has permissions for casuser to be able to write to it.
Sorry for bothering you. I knew the EoS by July 1 but still there is reason to install it.
Thanks for your kind help & advise.
Sachi
