LMS 2.5.1 and cygwin
ngholmieh
I have installed the latest cygwin on the Win2003 server running LMS 2.5.1.
I tried to run cron.exe, i got this error:
>>>>>> C:\cygwin\usr\sbin\cron.exe (1468): *** system shared memory version mismatch detected - 0x2D1E009C/0x75BE007A.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version. The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution. Rebooting is also suggested if you
are unable to find another cygwin DLL. <<<<<<
I searched for cygwin1.dll, and there is another older copy in the CSCOpx\bin directory.
Is it safe to delete (or maybe replace) the cygwin1.dll in CSCOpx\bin as requested in the error message, without messing up the ciscoworks installation or any ciscoworks mecanism?
Joe Clarke
Absolutely not. The cygwin1.dll that LMS ships is used by our tar.exe binary (required for backups). We actually have a known incompatibility with other copies of cygwin1.dll, and it is recommended for the time being NOT to install Cygwin, or any other Cygwin consumers on your LMS server.
