Webcast-Catalyst9k
LMS 2.5.1 Scheduled Backup - Path ends with a "."
Hi Everyone
I've experienced a strange problem regading the Scheduled Backup.
When trying to schedule a backup we recieve the following errormessage:
"Cannot schedule /cs/CW2000/CSCOpx/."
Notice the "."
I havend seen this error before...
Greetings
Jarle
1 REPLY
Re: LMS 2.5.1 Scheduled Backup - Path ends with a "."
I don't think its the '.' causing the problem. Is CiscoWorks installed in this directory because if so you cannot backup to the install directory.
It also should not be backed up on a system directory like /var or /tmp
You can possibly try creating a dir like /opt/backup and making sure casuser has write permissions.
If you look in the dbbackup.log or daemons.log you'll prob see a more specific error like:
INFO: Backup cannot be taken on /cs/CW2000/CSCOpx since CiscoWorks is
INFO: Please try again
98
