LMS 2.5.1 switch names
Hi...
I am using lms 2.5.1. The switch names (system name/host name) do not appear in the discovered device lists in campus manager, only IP addresses. They only appear in Detailed device report from the Device center.
I have read the cisco document and disabled reverse dns lookup but no result. I can add them manually to my dns server, but is there another way, since the names appear in the detailed device report and in Solar winds, without doing any DNS config.
All help is appreciated,
1 REPLY
Silver
Re: LMS 2.5.1 switch names
No,
Either the names come from a resolve (DNS or local hosts-file) or you enter them manualy. (Either via the gui or by editing an export from the DCR)
Ciscoworks does not have an option to use the system name. (except Campus topology view)
Cheers,
Michel
98
