LMS 2.5.1
I have been running LMS 2.5.1 for a while. Want to check how to achieve following:
1. Can I change the default telnet command to ssh when right-click a device in the campus topology service window?
2. For path analysis, is it possbile to add new applications in the drop down box when I right-click on a device?
3. again in the path analysis, is it possbile to show the sysname instead of the IP address?
1 REPLY
Re: LMS 2.5.1
1) the application that will be opend is determined by the config of the web client (the computer from which you start the web session to the LMS server)
for windows it is the Reg Key for telnet under
HK_Classes_ROOT\telnet\shell\open\command
change it to whatever you want and it should work
2) don´t think that it is possible
3) I do not know
MArtin
86
