Webcast-Catalyst9k
LMS 2.5 and AAA
I am having problems with LMS using ACS 4.0. We have set it up and now RME doesn't show any devices in device center, user tracking doesn't show up, while Topology services still works. This seems confusing, author isn't working right even though the ACS group is setup for Network Admin rights. WHat am I missing?
Re: LMS 2.5 and AAA
Have you setup the system identity account in LMS to reflect the username in ACS with the appropriate rights? By default it will still be 'admin' the default for local auth.
What switches do you have that user tracking isn't working for? I had trouble with 3750's because they cant use SNMPv3 with UT. Resolution is to use v2.
From what you have outlined above I think you actually have multiple issues rather than the one. Did everything work before you setup ACS auth?
Re: LMS 2.5 and AAA
You need to add the network devices in ACS as well. I think it should work if you log in using your Super User Account created in ACS.
121
СоздатьДля создания публикации, пожалуйста в систему
