Community Member
LMS 2.5 and HP OV NNM 7.5 integration
Hi, collegues! I have the following problem.
I have CW LMS 2.5 installed on Windows and HP OV NNM installed in Solaris server. I need to integrate them. After integration I try to launch CW-applications from the NNM map and get the message "Access Forbidden".
What may be the reason of it?
Re: LMS 2.5 and HP OV NNM 7.5 integration
Are there any error messages in NNMAdapter.log?
Did you stop ov and do ovtopofix after the integration was run?
Community Member
I didn't see any problems during installing adapter on NNM. The installation was successful. It seems to me that problem is caused of CW part.
The NNM is installed on Solaris and CW - on Windows system. I used Integration Utility 1.6! Is it possible to be the cause of problem?
The last time I saw something like this the integ utility had to be reinstalled
Please make sure you get it from here:
http://www.cisco.com/kobayashi/sw-center/cw2000/cmc3rd.shtml
100
