LMS 2.5 CM and D&C
Does anyone know why devices discovered by Campus Mgr via its decvice discovery tools do not end up in the Device and Credentials repository?
Red
Re: LMS 2.5 CM and D&C
DeviceDiscovery will not send Unreachable devices to Device and Credentials
Why does CM set the status of the devices it discovered to "UnReachable" and is there a way to correct this?
Thanks for the reply.
Red
Unreachable could be incorrect SNMP configuration or timeout
I confirmed SNMP community string works by doing a MIB walk. Is this an old problem that there is a fix for?
A device can be discoverd by CDP neighbour through one of its neighbour devices but it could be that it has an access-list or snmp-view configured so that the management station cannot reach it via SNMP. Make sure SNMP communication works from the *management station* to the device: open DeviceCenter and enter the IP address of the device, down left you will get "SNMP Walk". Enter the community string and enter "system" as the OID. If the communication is ok, enter the community for the *IP* of that device in the SNMP config dialog for discovery and restart the disco.
HTH,
Martin
102
