You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
LMS 2.5 configuration
Hi, i have ciscoworks2.5 LMS tool, is there any link or document available on net through which i can easily configure it on my windows server
  • Network Management
Re: LMS 2.5 configuration
Thanx for your help,
sorry i have no CCO login
so can i get it from any other link
again, i have no CCO login, how i can get this doc.
Now, what are the confg. change is required on managed router/switch in terms of SNMP support, protocol, syslog etc....
Can you reach this link:
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_quick_start09186a00805af28a.html
You need to enable snmp ro/rw on your devices to manage them in LMS. Also, you can setup other attributes like telnet, enable or tacacs authentication. Syslog would be enabled by the logging command
yes, i can reach this link, Is there any config. difference between LMS 2.5 and LMS 2.5.1,
Is this link can help me fully to config. LMS 2.5 on windows server
LMS 2.5 and 2.5.1 are essentially the same. This guide should help you get LMS installed and walk you through setting it up to work.
Hi, I am config. LMS 2.5 on window server, the 1st CD i have installed is Commom services, In Server-Admin-Process management is shows services,jrm, CMFOGSServer, CmfDbEngine, ESS, LicenceServer, Proxy, EDS-TR, RmeGatekeeper, RmeOrb, TomcatMonitor are (shows program started, no mgt. msgs received)
what is this ?
These are LMS internal processes and from the status you are showing they are running fine.
149
