09-29-2005 06:07 AM
Hi All
I'm running tests for a migration from LMS 2.2 (Common Services, SP3 and RME IDU 13) to LMS 2.5 (Common Services and RME) running on Windows 2000 Server SP3
When I try to restore data to the new server using restorebackup.pl I see the following error in the migration log and this seems to break RME
<snip>
Started at: ----------> 2005/09/29 14:11:27
29/Sep/2005 14:11:27:484 0 [main] INFO com.cisco.nm.rmeng.migration.MigrMain ? - Constructor: D:\PROGRA~1\CSCOpx
29/Sep/2005 14:11:27:484 0 [main] INFO com.cisco.nm.rmeng.migration.MigrMain ? - Initializing the setup for migration framework..
29/Sep/2005 14:11:27:484 0 [main] INFO com.cisco.nm.rmeng.migration.MigrMain ? - Check if the Database engines are up...
29/Sep/2005 14:11:27:515 31 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Command to execute is : D:\PROGRA~1\CSCOpx\bin\pdshow.cmd EssentialsDbEngine
29/Sep/2005 14:11:27:609 125 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Successfully executed: D:\PROGRA~1\CSCOpx\bin\pdshow.cmd EssentialsDbEngine
29/Sep/2005 14:11:27:609 125 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Process output is: Process= EssentialsDbEngine State = Program started - No mgt msgs received Pid = 852 RC = 0 Signo = 0 Start = 09/29/2005 02:07:33 PM Stop = Not applicable Core = Not applicable Info = Application started by administrator request.
29/Sep/2005 14:11:27:625 141 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Matchedd.....
29/Sep/2005 14:11:27:625 141 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Command to execute is : D:\PROGRA~1\CSCOpx\bin\pdshow.cmd RMEDbEngine
29/Sep/2005 14:11:27:656 172 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Successfully executed: D:\PROGRA~1\CSCOpx\bin\pdshow.cmd RMEDbEngine
29/Sep/2005 14:11:27:656 172 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Process output is: Process= RMEDbEngine State = Never started Pid = 0 RC = 0 Signo = 0 Start = N/A Stop = Not applicable Core = Not applicable Info = Not applicable,
29/Sep/2005 14:11:27:671 187 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Not matched.....
29/Sep/2005 14:11:27:671 187 [main] FATAL com.cisco.nm.rmeng.migration.MigrMain ? - Essentials 4x db is down..
29/Sep/2005 14:11:27:671 187 [main] INFO com.cisco.nm.rmeng.migration.MigrMain ? - Essentials 3x database is down...
29/Sep/2005 14:11:27:671 187 [main] INFO com.cisco.nm.rmeng.migration.MigrMain ? - Stopping migration process ....
<snip>
Does anyone have any ideas about this ?
Many thanks in advance for any help
Kind regards
Marcus
Solved! Go to Solution.
09-29-2005 06:31 AM
I doubt that this has anything to do with the fact that it's an eval
Did you install any Common Services 3.0 Service Packs before trying the restore?
09-29-2005 06:12 AM
It's only installed with an eval license, by-the-way, as it's only a test at the moment - Not sure whether this would prevent the restore from running though ...
User accounts etc have restored successfully, it's just the restore of RME data which fails
09-29-2005 06:31 AM
09-29-2005 01:04 PM
Many thanks for your reply Nadim
It's just Common Services 3.0 with RME 4.0 at the moment - No Services packs or IDU's
I'll add any patches I can find for this edition of CiscoWorks and see whether this makes a difference
Cheers
Marcus
09-30-2005 03:05 AM
Hi Nadim
I've successfully run restorebackup.pl after adding Common Services SP2 and RME SP2
Many thanks for your help :)
Kind regards
Marcus
09-30-2005 03:47 AM
Glad to hear it. Have a nice week-end.
