LMS 2.5 discovering devices over ISDN?
I am trying to discover devices via BRI interfaces via a 3640 and 3725. Using seeds, router hops etc. seems to have no impact on the ability to discover these devices.
Do I need specific encapsulation the BRI interfaces?
I've enabled CDP discovery on the BRI interfaces but this has made no difference.
Any ideas / clues as to where I should be looking?
Thanks.
Silver
Re: LMS 2.5 discovering devices over ISDN?
check out the following link on Troubleshooting the ANI Discovery Used by Campus Manager and User Tracking :
http://www.cisco.com/en/US/customer/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml
OK, checked everything out and I'm getting:
Getting the message:
3w3d: CDP-EV: Encapsulation on interface BRI2/0 failed
3w3d: CDP-EV: Encapsulation on interface BRI2/1 failed
Just using normal PPP encapsultion on the BRI line with image 3725-js-mz.122-15.T17.bin
Do I need to change the encapsultion, type of image or ..... ??
Thanks.
If you read the document
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml#topic1
you find this:
"Basic Rate Interfaces (BRIs) do not support CDP. Enhancement request CSCdu20683 is opened against this. As a workaround, configure a dialer map to send the CDP packets. CDP is supported on dialer interfaces. "
in the Bugtool CSCdu20683 is not listed.
regards,
Martin
94
