LMS 2.5 IDU 13.0 Auto archiving of configs not working
I have a problem on Ciscoworks LMS 2.5 running IDU 13.0 on Solaris platform where auto archiving of config files has stopped working.
Ciscoworks is set to pull off any updated configs once a week every Sunday at 23:00hrs.
If you try an update archive and manually select some devices that you know the config has changes on you can see that in the directory
var/adm/CSCOpx/files/archive
The files there with the current date on them so you know this means the manual process works ok. This also means that there are rights to write files to on that directory of the Solaris server.
The daemon manager has been stopped and started but this has not helped. It looks like it has been like this for some time.
To check the auto archive setting you need to do the following in RME.
RME-->Admin-->config management-->General setup-->Config Manager Admin
From here you can see the Arcive directory and select this and in "change probe setup" tab you can alter how often the change probe automatically detects and initiates the retrieval of new config versions.
Has anyone seen this before and if so is there any way of easily troubleshooting why the auto archiving is not working.
Thanks for your help
Dave
118
