Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
LMS 2.5 Installation
I was advised to install LMS 2.5 on a separate server from the current live LMS 2.2 version I have running. Is it an upgrade where I have to install the older version first or can I do a clean install with the new 2.5 CD's?
1 ACCEPTED SOLUTION
Re: LMS 2.5 Installation
You can do a clean installation of 2.5 on the new system. If you have an upgrade license, you will need to validate your LMS 2.5/2.6 installation by pointing to the existing 2.2 server. Validating an upgrade is documented in the installation guide.
1 REPLY
111
