LMS 2.5 Optimization.
I am currently running LMS 2.5 on Windows 2003 Server. The server has 2-3.2G Xeon's 4G of RAM and 216G of Hard Drive space. While I am on the server I go to task manager and look at the performance and the processors are not being used hardly at all but I am using like 7G or memory. I am using like 4G of Page file and the reset is physical memory. Is there a way to optimize the server to run smoother and not use so much resources? Also when I look at the task manage all the memory is being used by ciscoworks processes.
  • Network Management
1 REPLY
Silver
Re: LMS 2.5 Optimization.
Here are some points to improve CW2K GUI performance:
1. On PC, use IE not later than 5.5, preferrably 6. Make sure that IE contains the Java Virtual
Machine. Some installations of IE dont.
2. Make sure that DNS is configured and is operational on the CW2K machine. DNS is a requirement for proper CW2K operation.
3. In your browser increase the cache size for both memory and disk cache.
4. Increase the cache size of the Java virtual machine:
105
