Webcast-Catalyst9k
LMS 2.5 - RME Issues
running - CM0002: Could not archive config Cause: Device may not be reachable, may be in suspended state or credentials may be incorrect. Action: Verify that device is managed, credentials are correct and file system has correct permissions. Increase timeout value, if required.
startup - successful.
This is in config management.
1 REPLY
Re: LMS 2.5 - RME Issues
Is the device reachable?
Can you telnet or ssh to the device and login with the same credentials the application has assigned?
Is the device in a suspended state?
If you're able to backup other devices, this would probably rule out file systems and file permissions...
121
