LMS 2.5 Solaris 9.0 CS3.0 installation keeps running on: ../install/yes.sol
Dear NetPro's,
I try to install CS 3.0 on Solaris 9.0 but my installation keeps running. With the command "ps -ef" I see about 30 processes running, called "/opt/tmp1/install/yes.sol" taking together 100% CPU. At this point in the installation process I waited 5 hours more (SunFire 280R with 2 CPU 2 GB RAM) but no change in the installation process. Second attemp same problem.
I use the latest Solaris 9 Recommended Patch Cluster of Sep/22/05. In a test environment with Recommended Patch Cluster of Aug/08/05 I had no problems.
This are the last lines in the installation log:
INFO: registering with CMIC.........
INFO: CMICReg /opt/CSCOpx/lib/jre/bin/java -cp /opt/CSCOpx/lib/classpath/cmic.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/MICE.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/NATIVE.jar:/opt/CSCOpx/MDC/tomcat/webapps/cwhp/WEB-INF/lib/log4j.jar:/opt/CSCOpx/MDC/tomcat/shared/lib/xerces.jar com.cisco.nm.cmf.cmic.registry.CMICApplicationRegistry cv.6.1 0 register
Any idea? Someone with the same problem?
Red
Re: LMS 2.5 Solaris 9.0 CS3.0 installation keeps running on: ../
I had the exact same problem when setting up a test server.
Found that i used zsh when executing the setup script.
Reinstalled the whole thing using /bin/sh
Worked perfectly
Might be worth a try if you are using any other shell than /bin/sh
108
