02-23-2007 01:47 PM
HI,
I installed LMS 2,5, and I have some you doubt.
After the installation I can go up schemes it in the domain?
After the installation can be used clone of the using Administrator?
It has some problem if to install antivirus?
02-23-2007 01:50 PM
I don't understand the first two questions, but as for the third, there are no known problems with installation with anti-virus software enabled. However, we never did any formal testing with any anti-virus software. It would make things faster to disable any kind of on-access scanning during installation.
02-23-2007 02:03 PM
I followed the recommendations of that an user could not install the LMS using clone of administrator of the server, also could not be in a local domain the server. This is fact?
02-23-2007 02:05 PM
Ah, I think I understand. LMS installation must be done as a local Administrator (i.e. a user in the Administrators group). The Windows server can be part of a domain at the time, but the installation must be done as a user that can modify the local SAM and Registry.
02-23-2007 02:53 PM
This exactly. But the server was is of the domain, does not have problems in placing in the certain domain?
which the best option, to leave the server blocked with the using administrator, or to make logof?
02-23-2007 08:34 PM
An LMS server can be added to a domain as a member, but not a PDC or BDC. Once LMS is installed, there is no reason to leave the Administrator logged in to the machine.
