Bronze
LMS 2.5
I just installed LMS 2.5 witht he following applications:
RME, Campus Manager, DFM, and CiscoView
From the ciscoworks homepage i can see common services, campus manager, and ciscoview.
I clicked over homepage-> application registration and select Registration -> Register from templates -> RME -> and type the required parameters
server name, display name, and the port 1741 with http. I did that since i can't see the RME at the homepage.
Now, i can see the RME at the homepage, but the problem when i click over any link in the RME i got Error 404 Not Found.
I have a good background about Appatche, i can't see the RME folder in the CSCOpx>htdocs> i think that the reason for the 404 error message. I think that path is where the appatche read the ciscoworks files for the web management.
Any help?
Thanks in advance
Abd Alqader
Silver
Re: LMS 2.5
In the install log check for the string "Registering with CMIC" and see the status of the command CMICApplicationRegistry
Bronze
Re: LMS 2.5
thanks for your reply. But where i can find the install log file?
Thanks in advance
Abd Alqader
Re: LMS 2.5
Which OS is the Ciscoworks installed on?
For Windows the log will be under :\Ciscoworksxxxxxx.log ( eg C:\Ciscoworks_install_20050126_194013.log)..
For solaris, it will be under /var/tmp
The reason you are not able to see the RME after installation could be because of some error during install. So check for any "ERROR" strings in the logfile generally.
111
