LMS 2.6 and HP Openview 7.5
kanokpan
Does anyone know it LMS 2.6 can integrate with HP Openview Network Node Manager 7.5 ? Or can i install integration utility 1.7 to LMS 2.6 server in order to communication with openview 7.5 ?
Jan
2 Accepted Solutions
David Stanford
Yes, it does integrate with NNM 7.5:
If they are to be on same server, you can download and install Adapter.v1-7.sol.nnm.tar (assuming solaris) to CW box.
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-nnm
(also download readme for directions).
Readme does mentions:
Adapter(Version 1.7) for integrating Cisco Applications and Cisco Devices into HP Network Node Manager 6.4 , 7.0 , 7.01 and 7.5 versions
If you are installing NNM on separate server, you can install the Integration Utility (IU) on the remote server where HP NNM is installed which you may download from this link:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-utility
Yes that's right, you can do this with LMS 2.6
David Stanford
Thank you very much.
So I can just install Integration Utility 1.7 into Openview 7.5 without upgrading ciscowork to LMS 3, right ?
Jan.
