07-26-2010 11:01 AM
Does anyone know if LMS 2.6 will manage c3560x devices?
Solved! Go to Solution.
07-28-2010 03:25 PM
Unfortunately, this device is not supported in LMS 2.6. It is, however, supported in LMS 3.2.
07-26-2010 11:56 AM
Yes, it will. LMS 2.6 with all of the latest device updates will manage quite a few 3560 models. To know if your specific model is supported, you will need to provide the sysObjectID.
07-27-2010 11:21 AM
Joe
Thanks for the reply
The actual device that I have is the following:
WS-C3560X-48P-S
I don't see this exact device in the list when I try to add it under CS.
I also updated devices for RME.
07-28-2010 12:16 PM
Joe
Here is the sysObjectID 1.3.6.1.4.1.9.1.1229
Thanks for the help
07-28-2010 03:25 PM
07-29-2010 06:01 AM
Joe
Thanks for the info. I guess there is little chance that 2.6 will support it?
07-29-2010 09:10 PM
Right. There is no device support planned for LMS 2.6.
