Blue
LMS 2.6 dcrcli - authentication failure
I don't want to set DCRCLIFILE env at this point. The problem is /opt/CSCOpx/bin/dcrcli -u admin exp fn=/path/to/homedir/dev.csv ft=csv seems to fail to accept the perfectly valid password for the user.
1 ACCEPTED SOLUTION
Re: LMS 2.6 dcrcli - authentication failure
Try dcrcli -u admin cmd=exp fn=dev.csv ft=csv
Blue
Doing this in two steps works, but not ideal:
dcrcli> exp fn=dev.csv ft=csv
121
