11-01-2006 07:30 AM
I am trying to get everything discovered on the new lms2.6 server. I have gradually opened up the ip ranges for discovery but something is off. I am stuck at 272 Devices in the L2 map. When I look at Campus mgr home I see 342 devices discovered.
Thanks for any advice
11-01-2006 07:45 AM
What is the status of these devices? Are all 342 reachable and known? If you click on the number 342 in Device Discovery you should see a list of the devices it picked up.
you can then see why there is a discrepancy, perhaps some devices are not reachable.
11-01-2006 08:23 AM
I did that and 14 are in an unreachable state. Most of those are firewall related issue that I am dealing with. So I am still puzzled about the remaining that are reachable but do not populate the map
11-01-2006 08:31 AM
Here's what you can do to troubleshoot:
Start with 1 device that is missing from the map and is in the other list:
- Is it in a reachable state?
- Is it a supported device? Some devices can be snmp and cdp supported, but not supported by the app
- Are the snmp comm strings correct? Can you snmpwalk it from LMS?
- Is CDP enabled?
If all of the above are correct then:
- Add it as a seed device? Does it appear?
- Is it on the other side of a firewall? Remember firewall won't pass CDP (layer 2)
If it still doesn't work then you may want to enable debugs in CM
