Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
LMS 2.6 device selector behavior
Depend on username the device selector shows different possibilities.
if i use my username (not admin but full rights ) the device selector give the different switch types under "device type groups" and "switches and hubs" .( 2950, 3550 etc. )
If i use other uername ( full rights also ) only the ip addresses are seen under "switches and hubs".
The first case is convenient for us.
Where is the different in user settings ???
Re: LMS 2.6 device selector behavior
The device selector can be configured on a per-user basis under Common Services > Device and Credentials > Device Selector Settings.
Hi Clrake,
It wassimple but useful.
i did not sense this option eralier.
Thanks again.
107
