LMS 2.6 DFM Suspending Device Component
acalligher
hello
After I suspend a device component (ex. Interface of a router), does it possible to see a list of devices with suspended component?
I like to remove recurrents low priority alarms.
Best Regards
Andrea
Joe Clarke
I'm assuming you mean you unmanaged components in the Detailed Device View. If so, then there is no way to get a list of devices that have components with a management state of false.
Exactly, so in this case maybe it better to place in suspend state the device.
I will avoid to forget the unmanaged components.
bye
andrea
You can also create views that only filter on the devices you care about (under DFM > Configuration > Other Configurations > Alerts and Activities Defaults). This way, you can still manage the devices, but cut down the unwanted alerts in AAD.
