LMS 2.6 Invertory problems
I am getting this error on my inventory jobs on some devices.
RICS0001:Internal Error,unable to process the collected data from the device.
Any help in why this is happening so I can fix it. I have done an IOS update on some of these devices and the Inventory is not collecting the new version.
Re: LMS 2.6 Invertory problems
Exactly what version of RME do you have? What errors do you see in the IC_Server.log?
RME vs 4.0.5 I have attached the IC_Server.log
You will first need to upgrade to Common Services 3.0.6 and RME 4.0.6 to get a fix for CSCse52700. Then you will need to remove the failing devices from RME and re-add them. If the problem persists after that, you could be hitting CSCsm97530 as well which will mean you'll need to contact TAC to get a patch.
When using the software update feature in Common Services, I only get updates for cm rme and dfm. there is no update listed for common servies.
142
