Community Member
LMS 2.6 layer 3 topology discovery
Would you please tell me if LMS 2.6 is able to show L3 topology ("LAN Edge View" in Campus Manager)?
Does Campus Manager discover connectivity and show connections between devices relying only on CDP?
Is it possible to manually add connections on the topology views?
Thanks in advance,
Mladen
1 ACCEPTED SOLUTION
Re: LMS 2.6 layer 3 topology discovery
Campus Manager topology is layer 2 only. The LAN Edge View shows switch clouds bordered by routers. Campus Manager relies on CDP, ILMI, and ELMI to build its topology information. You cannot manually add connections to the topology map.
1 REPLY
123
